This motor is not oil injected so the overheat horn is all I have to deal with. Let me give you a little background. My boat came with a Johnson J115TSLECM about 3 years ago the warning horn quit working. I never could get it working after that. That Johnson went bad on me and I lucked into a deal on the identical model Evinrude E115TSLECM. The swap was easy Just switch motors and plug in the Evinrude. I hoped the warning horn would magically start working but no such luck. I did put on a new keyswitch when I did the motor swap. This afternoon I hooked up 12 volts directly to the horn and it sounded so that is not the problem.
If anybody is familliar with the 115 SPL model I would apreciate some guidance. I've tested the horn/buzzer and it works. Since neither my old Johnson or the Evinrude would sound the horn when the key is turned on I suspect it may be the wireing harness but don't have a clue how to troubleshoot this.
