enginesilo
Thread starter- Joined
- Jun 9, 2008
- 355
My boat has a buzzer under the dash, and the wiring for the probes, but does not have them installed. Is there any way to test to see if the wiring is all functional and the buzzer? If I understand correctly the sensors are simply a relay that stays closed and when they reach their alarm point they close and make a connection, is that accurate?
So to test, should that mean that I can take a piece of wire stripped at both ends and enter it into the tan/blue wire, and the black wire that sits near the thermostat where the temperature sensor sits? Would that activate and make the buzzer sound?
Right now when I turn the key the buzzer does not make any noise. I do hear a chirp, but I think that may be my build in depth finder possibly.
I'm considering installing the sensors but I want to confirm everything that is existing is working as is. How can I test it and activate the buzzer?
I have a Searay boat by the way with the 3.0L Mercruiser engine.
