Loose throttle......
Gradywhite3535
Whenever I'm out on the water I've been noticing the throttle seems to be loose and moving forward. Is there any adjustments to make it loose or tight? Thanks
Gradywhite3535
It's a 2003 yamaha txrb 130. I tried uploading a photo of the controller but it's not working. Ard the screws you are talking about under a black rubber circle? I remember seeing two screws there. Thank you
99yam40
motor model does not have any bearing on the controller model
have a look around for 703 and 704 to see if those might be what you have
Gradywhite3535
Just took a look at my manual for the control lever that I forgot I had and found the directions. Is The throttle opening adjustment on the control lever out it in forward or reverse closer/further?
99yam40
Sorry but that question does not make any since to me
