2006 honda 15 hp to 20 hp?
dkonrai
have to ask. i have a 15 hp honda and wondered if i install a 20 hp carb is it now a 20? am i just crazy?
thanks
dino
Sea Rider
That's a wild guess, get Honda spare parts manual for both models and check external/internal differences, if being carbed probably will only need a carb swap or same carb + advance timing, carb restrictor, fuel intake, leaf valves size ?
Happy Boating
dkonrai
from what i can see, comparing both motors, is the carb body is the same but internals are different. the cdi is also different. all the rest is identical. just checking to see if anyone has tried this.
dino
Sea Rider
Does both 15 & 20 HP models have same CC, being the15 a restricted model to the 20. If not, probably can't be upgraded, seems 2 different horses.
Happy Boating
dkonrai
yes the 15 shares the same cc's as the 20. im thinking its a detuned 20.
dino
Sea Rider
dino
Check both model phyisical differences, carb, carb restrictions if any, throttle cams, reed valves assy, timing. Each engine brand ​has its own tech ways to detune/upgrade same CC engines. Will need a Honda spare parts manual to do so.
Happy Boating
dkonrai
more research tells me a cam swap is needed as well. o well. guess i will live with the 15 :)
