fierodough
Thread starter- Joined
- Jun 16, 2012
- 17
The engine is a 175HP XR2 from a Doral jet boat.
I have low compression on the 3 cylinders on the starboard side.
Port side is 130psi, 130psi, 130psi
Starboard is 20pse, 90psi, 20psi.
I took the head off and this is what the head gasket looks like:
Top cylinder 20psi
Middle cylinder 90psi
Lower cylinder 20psi:
I'm concerned because the compression ring portion of the head gasket looks intact. I can't really tell where it was leaking.
I have some scoring in the cylinders but nothing that seems critical..
Here is the head after cleaning and resurfacing. (it was slightly warped, probably still within spec but made it perfect)
I ordered the new head gasket and hope that will solve the problem. Would there be anything else that would only affect the 3 cylinders on the starboard side and leave the port side cylinders intact?
How many reeds on this type of engine? Is there separate reeds for port and starboard? and do the reeds affect compression readings?
Thanks guys! I'm very familiar with automotive engines but when it comes to marine, I'm a fish out of water..
Cheers!
Top cylinder 20psi
Cheers!
