~~I have installed all new fuel lines. Tried 2 new tanks
Rebuilt all 3 carbs, Rebuilt fuel pump
I installed a new head gasket
Black coils and boxes.
135psi all 3 cylinders
The engine will idle all day and run up to about 4000 rpm without any issues. I can cruse at 25mph like it's should. It will jump out of the hole great any time. The problem is after about 4000rpm. If you go full throttle it will run up to 5000 rpm then surge between 5k and 4k back and forth. Back the throttle to about 4k and all is well again. I have a clear glass fuel filter at the fuel pump. I have a friend watch the fuel filter. It never runs dry. I have clear fuel lines to the carbs. They never run dry. The plugs look black and wet but never have fouled. I have read many similar posts about this engine but never have read a real fix. I checked the fuel recirculation system. It seems ok but I don't know much about it. Any help Please.
