Ok, so we are getting ready to head to 1000 Islands. Fired up the ol' Johnson. runs good, but smokes badly. I was convinced I had screwed up the mixture. Changed plugs, old plugs only had about 8 hrs use. Looked wet but not really fouled. 2nd tank of new fuel, mixed TCW-3 at 24:1. Running Premium Non-ethanol, with Marine Stabil just in case. Still smoked, seems worse above idle, gets worse as rpms increase. Main jet adjusted as lean as I can get it w/o having it sneeze. Pulled plugs, look kinda wet but not oily. Running in a barrel. Water has lots of pukey light green oilfoam, but no black goop. Disassembled carb thinking maybe float prob. Blew cleaner through all ports and jets. All internal carb parts were new last season. Reassembled. Starts and runs ok. Idles ok. But still smokes alot above idle. This thing ran perfectly clean last season. Only thing I can think of is different oil. I have never used the Carquest Marine oil before. Anybody have any experience? Could it make that much difference? Previously used Pennzoil and Wally World Supertech.
