Post count
Status
Not open for further replies.
jbcurt00
Hey, wait a minute, how are you getting multiple quotes all in 1 post. I tried earlier & it didn't recognize the code for any quoted texts beyond the 1st......
GA_Boater
^^^^ something else you can't do. Posts must be 3 or more characters. I'll explain in a bit. Remember in another topic I said I could do everything I wanted to do in the forum. :D
jbcurt00
QUOTE=GA_Boater;n7704407]?COLOR=#FFFFFF]??[/COLOR[/QUOTE
charlatan
GA_Boater
Aw - I'm a double charlatan. :lol: Since multi quotes aren't turned on yet, I devised my own way. Simply repetitive cut/pastes. That's all. But when it helps explain something, I'll do the painful process until it's enabled in the software. Or since the upgrade was done for increased security, I'll hack it and turn multi quote on.
OK - That's a joke.
jbcurt00
Hmm, I think I tried cut & paste, but maybe I was just putting the {quote] {/quote] Bbcode before & after the text I was typing. It was an attempt to say something like this:
I didn't say that
To which I replied:
Yes you did
The forum software only recognized the 1st set of quotes
Using the nifty new Preview button, I checked & now both those ^^^ quotes showed up as quotes. Go figure
Every forum I'm on is a drastically different setup, but the Bb codes are all pretty much the same. I regularly jump back & forth, so I often type the codes rather then using the editor features....
That's were I grabbed my new favorite smiley:
GA_Boater
First I quote, then copy
your abbreviated post #1
cancel the reply, find another post to quote, paste #1 above the new quote
IIIII ? #2
Then copy the whole thing, cancel the reply and find the next post to quote and paste the previous combo quote above the new quote
IIIII ? #2
... of course it would flip on that post. :dizzy: #3
Just keep it up for all the quotes and what you want to add and post the reply. You can cross quote from other topics, even other forums that use VB. Needless to say, you have to Preview a lot to keep everything straight.
Just a workaround to roll your own M-Q until M-Q gets enabled. Yes - It's a PITA, but it gets the job done. :smile:
Clever trick GA :hail:
OK - That's a joke.
Not a trick, some of us have been doing it for a while - it helps to have word or notepad open to cut-n-paste
toneeees
Administrator
To which I replied:
Multi Quote works, simply select the "Quote" button on posts you wish to quote and then click the yellowish-gold button that says "Post Reply" should be on top of the page.
MTboatguy
toneeees, I am curious as to why, the moderators as well as your administrator designation is now display * asterisk symbol instead of your designation spelled out? I noticed this the other day when one of the moderators posted.
MTboatguy
Wow, just noticed, I only have 2 more posts to go until I hit 3000 posts, so I guess it is counting my posts.
MTboatguy
Really I was not post padding, just wanted to see if the posts counts were working for me!
:D
southkogs
ooooooooohhhhhhhhhhh ... who knew?
​Thanks Toneeees
Fun Times
It should just be an adjustment setting that one of the administrators will eventually find in one of the control panels once again. The Mod title has come and gone a few times now over the course of adjustments. At this time, certain cosmetics features and benefits are lower priority than others.;) Thanks for being positive and helping out iboats through these trying times MT, Much appreciated.:)
southkogs
Sorry guys ...
Just using this thread ...
Yup, one more to go!
... to spread the word.
Status
