Bimini top with privacy "walls"?
rhino_160
I currently have a standard Bimini top on my toon. I am searching for one that has some sort of "wall" privacy for the sides, back, and front. Ones that are the same fabric as the top that just roll down when in use and roll back up when not. Anyone know of a company or place that sales something like this?? Thanks
MinUph
Your local canvas shop should be able to make it up for you.
jetboater
Yes. And also they should be able to add side curtains to your existing Bimini top if you prefer to do that rather than buy a new one--either by sewing zippers to the edges or using snaps along the edges. Then you could either roll up the curtains or remove them altogether
kjsAZ
I went the el-cheapo way after I saw some overpriced clamps online (http://www.biminiclip.com) . Bought the same sunbrella material as the bimini, took ~6" pieces of a PVC pipe with the same ID as the bimini poles and cut them open on the table saw lengthwise. Now I can clamp the curtains to the bimini poles when I want them and just pull them down when I drive. As the PVC is so cheap I don't have to punish the kids when they drop one into the water.........
