1987 marineer 150 manual says no air/fuel screws
jsaylor
I have a 1987 mariner 150 serial 0b117356, manual says there aren't any screws to adjust air/fuel, simply idle air bleeds, however I do have screws to adjust, what would be a good starting point, (how many turns from lightly seated.)
Some of the V6 Mercs had fixed idle jets, but most had adjustable idle mixtures. Maybe your carbs are from a different year motor?
wired247
You shouldn't if they are correct for the year WH carbs . . What carbs do you have? Theres letters cast into the top i.e. WMV or WMH and numbers stamped on the side flange.
jsaylor
Just looked at the top of the carb, as best as I can tell it looks like WH-33-1 other numbers on top are 2493
Thanks
jsaylor
After looking at a few parts warehouses I noted my carb WH-33, which is correct for my year and serial number however they all were non adjustable jets. Do you suppose someone changed from fixed to adjustable? should I change back? I also noticed when I lightly seated one it didn't make any difference.
Dukedog
Those are right, WH series use an "idle circuit only",adjusted only with a jet change. "Screws" came out with tha WMH series on tha V6 in '90......Uses a different linkage and throttle cam also..........jan. if its had a power head change serial no. on tha clamp bracket isn't any good.
jsaylor
Thanks for taking the time, I'm a bit confused as to what I should do, sounds like someone put the wrong parts in, should I change back to the fixed jets?
jsaylor
I've attached pics of the carb, let me know what else I should take a pic of. And again I thanks you
wired247
Your pics arent working. Mat want to post a link to an external picture hosting site. iboats is having problems these days. Must have gotten a good deal from the government on used websites.
Dukedog
Can't "put in" wrong parts. coupla jets are they only thing that will swap out.
jsaylor
I wonder why you can't see them? I just have pics of the air/fuel screws, should I take other pics?
Dukedog
picture of top of top carb........email to allysun260@sbcglobal.net.
they are still havin' problems here. my pic will show up fine with tha reply but won't show on "post".
Dukedog
he may be like me. tried "every way" possible.....no wayno. can get it ta show in tha reply set but when it goes ta post it goes away. got one ta actually post. it went away tha next day all on its own...........calf rope!
Dukedog
jsaylor go back to your post with tha picture ad hit edit. when that shows hit "restore" in tha text above ta see if it reloads.......
