Ok, first of all, I am an accountant by trade so you may have to use small words and speak slowly here!!
I have turned a wrench or two in my life, handling almost anything outside of an engine (rebuilt axles on Jeeps, install lockers in diffs, even replaced stuff on the outside of motor) so not 100% newb but not an engine/carb guy.
With that in mind, paid a local Marina last year to rebuild my carbs...and $1071 later they fixed all sorts of other stuff too and I they put in a impeller kit and a $150 charge for water pump service and various other things.
So, Saturday, got to the lake, backed in, engine fires right up, I let it run at 2500+ rpm for 5 minutes or so maybe while I screw around with other stuff, letting it good warm up and stuff.
Back off, towards idle, and it shuts off. No big deal (took a couple attempts to start it the first time and keep running, typical carb)
But now it will not start, doesn't act like it wants too, battery getting weak...kept trying for 10 minutes or so thinking it was flooded, sigh. Pull it out, went home, charged the battery AND bought a new one, hooked it up to the new one, cranked right up at home shut off.
Sunday...cranks like a beauty, ran it for less than five minutes warming up, backed off slower this time, gets to idle and running good, yeah!!
Backed out onto the lake, we are moving... started driving, everything looks good, but does seem to be running warm, gauge says 220+230ish? I am running 2000 rpm maybe, watch this closely, maybe creeps up to the solid 230+ No idea if the temp is supposed to be a 210 thermostat but I am guessing not.
Start smelling oil stuff, ran around for 5-10 minutes at most...came back into the dock. Backed off the throttle considerably (I had done this once or twice but never below say 1000 rpm) and the smell is getting worse, engine stalls.
I pulled the engine cover, engine is def hot (gauge is closer to 240 now) and the smell is basically the oil on the outside of the engine is burning off from various places.
I am 30 yards from dock, tried to start for the heck of it and acting funny (like Saturday) and not wanting to crank but no big deal I had it drifting where I wanted to go anyways. Drift up, load it up go home.
Tried cranking it when I get home (30 minutes or so) still acting like it does not want to start... come back an hour+ later and it DOES crank up and run for 10-15 seconds and I shut it down. So I know the engine is not locked up...good!
Checked oil, maybe 1/2 quart low if that...looks fine.
So... here we are now.
First of all... I have a few questions I am hoping you can help me with.
I hooked up the ear muffs to the house and started the engine say a month or so ago. I remember seeing the temp gauge being higher than I would want, but that is all I remember.
Question #1. When I hook up the muffs, water seems to "also" shoot out of the sides on the muffs to the sides, I try to get the best fit I can. When the water is on those... should it ultimately run back out of the prop without the engine actually on?
Question #2 If the answer is no... where do I start testing here. I assume I start with hooking up the water and turning it on.. is there a hose on the motor I can unhook to confirm water is coming in/past the impeller? Must the engine be running? (it gets warm / overheats so I assume I have to check these things quickly)
Question #3 Should I run a hose into the input on the water pump instead skipping impeller process.
Basically... what are the steps to diagnose this from start to end. I can handle the process, just not sure where to start.
Finally...is there a good step by step guide out there in a book or such for me to use and not bother you? (Such as how to open and check that impeller? If I do so that would require me buying and replacing such and such seal so...?)
