CraigBarnard
Thread starter- Joined
- Nov 7, 2010
- 269
I have what I think may be an original mercruiser stern drive and the upper and lower gear oil oil chambers are two separate chambers.
When I checked the upper chamber this afternoon (after draining the lower) I heard air being sucked in as if it where under a vacuum.
I decided I should remove the top cover and have a look inside. The upper chamber was empty.
I was wondering if anyone knew of a common cause for this to happen.
Thanks
Thanks
