w317chester
Thread starter- Joined
- Jul 7, 2010
- 54
If possible I would like some advice for setting ignition timing in my 2003 (Boat yr model) Mercuiser 6.2L MX MPI. I have just had the engine completely remanufactured and need to set the ignition timing.
What I know about setting timing:
- I know the number 1 piston has to be at TDC initially
- I know how to adjust the distributor cap to advance/retard the timing
- I know how to check the timing with a timing light on the harmonic balancer
What I don't know or am unsure about:
- How do I set the distributor really close PRIOR TO STARTING engine so my timing is already set close to where it needs to be for when I start the engine for the fine timing adjustment
- Do I have to plug a computer or anything into the ECM to tell the computer to "go into timing mode"
- What's the correct amount of degrees of advance for initial timing and total timing
- and anything else I may not know
Any help is much appreciated!
