bluewaterboater
Thread starter- Joined
- Apr 24, 2011
- 37
I've been chasing a problem for 2 years or so now, see my past threads. It's been frustrating and costly. Thought it was fixed again recently at local marina but last night its back.
Here is the basics:
- i have a 1999 Sea Ray 190BR with a 4.3l engine EFI throttle body.
- at about 30-34mph it starts to pop but it is intermitant and doesn't happen all the time. Even out of the hole sometimes it pops or hesitates.
- Lately its starting to back fire or make a noise like a "fart" in the engine compartment too.
- just all around not performing the way it should.
- mechanic
I have had it looked at by 2 different marinas now. The one place has one mechanic and the other has three that have been in the business all their lives. When I had it in recently they replaced the ignition control module and they thought they got it but last night about 20 minutes into a cruise it started running badly again.
I have had the fuel system cleaned, fuel/water separator changed twice, plugs changed, wires changed, compression checked, cap and rotor changed, Ingition control module changed, fuel pump checked, tach checked.... and the list goes on.....
The last mechanics said with my 21p or 23p prop they can hit my rev limitor at high speeds but that my tach was working properly - this surprised me because last night again my tach goes wacky even when i'm not revving too high. I don't know if this has anything to do with the problem since they have run my boat without the tach as well. my computer shows no faults.
It seems the more diagnostics that are done and the more work i have done to it the worst it runs.
Can anyone help with suggestions or has anyone had this problem before?
Thanks!
Here is the basics:
- mechanic
Thanks!
