gonefishin485
Thread starter- Joined
- Jun 29, 2008
- 108
ok so ive come to the conclusion that im the proud owner of a haunted 1977 85hp johnson javelin.
i got this motor, mounted it on a ski boat project and got it running.
after many hours of testing, cleaning the carbs over and over again, taking every jet out, blowing thru the passages with an air compressor and running something thru the passages to make sure their clear, (sometimes at home, sometimes on the water) replacing the fuel lines from the fuel pump to the carbs, rebuilding the fuel pump, replacing the fuel line to the tank, replacing the primer bulb, and everything else i can imagine to get this motor right ive come to the conclusion its haunted, lemme tell you what the little ghosts and gremlins in it do.
i can crank it up and run it on the water hose for an hour or two and it will run and rev great. i can put it in the water and it will putt around at low rpms and rev in neutral just fine. when i full throttle the hot foot and get to cruising down the water, she shoots out like a missile and will scream at 5200 rpms with a 21 pitch omc prop for a couple thousand yards... then the ghosts and gremlins wake up.
it will start loosing rpms, and start to bog down. it wont stall but it wont go back to full throttle, sometimes if you let it run and idle for a while you can get it back running wide open, sometimes you have to pump the ever loving crap out of the primer bulb, sometimes if you hit the choke a couple times while your trying to plane out it will act right. either way the problem is always the same regardless of what i do. idle out the wake zone, get it up on a plane, go for a while and then the ghosts come out to play.
the motor has good compression on all 4 cylinders, hot spark on all 4, (pulled each wire off while it was running to try to find a dead cylinder, got shocked a bunch, wouldnt recommend it). drilled and tapped the water jacket for a tell tale and always have good water flow. so far the only way i was able to keep it going full throttle was while a friend i trust was driving the boat, i continually squeezed the primer bulb, pumping it, and it kept running at full throttle for quite a ways before my friend shut it down to wonder why it was running fine all of a sudden. so to try to eliminate as many problems as possible, i took the primer bulb off and hooked the fuel tank line straight to the fuel pump in the hopes i could find an issue with the primer bulb, line, or connections,but the gremlins re appeared.
i always feel like im so close to fixing this thing, but it acts up then im very close to turning this thing into an anchor. what is wrong with this thing?!? someone please help me before i lose my mind and the ghosts win. generally im good with outboard, i have a merc 500, and a suzuki dt 25 that run like clocks, but this haunted 85 is giving me the blues!
