enginesilo
Thread starter- Joined
- Jun 9, 2008
- 355
I have a 2005 Searay 180 Sport with the 3.0L Mercruiser and the Alpha 1 Gen 2 outdrive. I hit the edge of a sandbar and took a small chunk out of a prop blade so I want to get a new one and have the old one repaired and keep as a spare.
Eventually I may want to pull a tuber or a boarder, but for now I just cruise around. My boat is rated max RPM at 4400-4800 but i'm only getting around 4200 for whatever other reason.
Any other prop I should be considering for the benefits they bring? Definitely want to stay with an aluminum prop. Here is what Searay recommends:
Prop Size 14.25 x 21 AL
Max RPM's 4400-4800
Recommended Part #944868
3.0L MCM
Alpha 1 Gen 2 Outdrive
Ratio: 2.00:1
I've seen people on the boards recommend 19's instead of 21's, and also some recommend a 4 blade instead of a 3. Figure it would be nice to have a second prop that is better at doing certain things so I can then switch between them if ever needed.
Any recommendations? Or should I just go with another standard replacement blade of the same?
Max RPM's 4400-4800
3.0L MCM
Ratio: 2.00:1
