66mstgfsbk
Thread starter- Joined
- Feb 3, 2009
- 97
Ok so I got a 2002 mercruiser 5.0 with the alpha drive. The problem is the engine backfires out of the carb like a lean misfire. Had the carb rebuilt and flow benched all works good. I have 6-7 pounds field pressure at carb inlet. The free flow from the pump was a cup of fuel in 4 seconds. Plugs good, cap good, rotor good, firing order verified, compression at 170 all around. Even after the carb work still pops out intake. Has the thunderbolt ignition module that bolts to the riser. The timing before was at idle 4 degrees with 12 total, I set timing according to manual....I'd did not say anything about grounding a purple wire I checked twice. Set to 8 degrees and now have total of 16-18. I have chased my self round and round. Runs great in neutral with no load on muffs, in gear on muffs works great. As soon as it hits the water, Pops out the intake. After I reset the timing it has popped way more out intake. Fuel in tanks is fresh. This has happened once or twice over the years, give it throttle and it acted like it would clear out and run great. Now 3 years later it is unusable, great while idling in water but once throttle is applied pops and won't clear out or gain power. Any help is appreciated.
