- Joined
- Jul 7, 2010
- 15,125
I need a little direction y'all:
I've rewired my trailer (4 prong, full ground) and had everything working for a day or two. After that - poof - no joy on either tow vehicle.
What's happening: When i plug into the primary TV (just working with one to eliminate variables), the ground wire on the vehicle side is getting warm (the 4 prong plug is getting warm too), the tail lights (markers) dim to about 1/2 their brightness when the trailer is not plugged in and I get no driving / marker lights on the trailer. Trailer brake and signal lights are still working (these are LED lights).
What I've done: I've tapped a new hole in the trailer and grounded the white wire to that new hole. I've disconnected the side marker lights to make sure the path to the rear lights is not interrupted, I've tried with the trailer disconnected from the TV and have run a jumper cable from the boat trailer to the TV frame.
Still no joy ...
I'm kinda' at a loss in direction at this point, and don't know if I should be lookin' harder at the TV or at the trailer.
Any ideas are welcome.
Still no joy ...
