SSTKO81
- Joined
- Jun 1, 2009
- 354
I just finished freshening up my '81 merc. 140. reworked head, valves, rebuilt carb, new oil pump. I stabbed the distributor back in and set time to TDC. I've got spark when starting because I shocked the hell out of myself trying to test it.... But the engine seems to only want to fire while I'm cranking on the starter. As soon as I let go of my jumper it quits right then and there. I'm getting a lot of sputtering and a few back fires.
I guess my question is: is there a series of wiring jumps or bypasses I need to make in order to bench test this. I've checked all the wiring diagrams in the seloc manual and everything looks to be correct so at this point I don't know what else to do to make it start. I put my (+) battery cable on the starter, (-) on the block run a (+) jumper to the yellow/red terminal "s" on the slave solenoid, which then makes a click noise, then remote start from that "s" terminal to the Yellow Terminal on the slave solenoid. Crank crank crank, sputter sputter sputter. no dice.
any thoughts?
any thoughts?
