83mulligan
Thread starter- Joined
- Feb 7, 2009
- 687
Ok, I'm pretty sure the carbs on my 1999 Johnson 90 need to be pulled and cleaned. Its a new to me boat that had a lot of neglect. The engine runs fine sometimes and gets real laggy others. I've been through a lot of other things including replacing old fuel lines, plugs, adding my fuel water seperator from my old boat, running some sea foam through, etc. I've pulled the drain plugs on the carbs and ran a wire up in there. In a nutshell, i'd just like to start with fresh carbs and never run ethanol gas through it going forward. I fish on big water and want the peace of mind that everything is clean and up to date. I'm going to pull the fuel pickup from the tank and clean that.
My question is if i buy the carb rebuild kits, how complicated a job is this. I'm not a marine mechanic, but I've been around engines enough to be able to do things. There are 4 of them and I have a guy that will do them for 400 - 450 labor but I'm really considering doing it myself and having him to fall back on if I mess something up. So, anyone with experience on this carb want to chime in and give me some advice? Also, what kind of things will I need to do the job aside from the basic tools to pull and replace them?
