w317chester
Thread starter- Joined
- Jul 7, 2010
- 54
Exhaust "Explosion" or "Afterfire" in my 2003 6.2 MX MPI Mercuiser'
So I just finished installing my fresh completely remanufactured engine into my boat. The engine is a 6.2 MX MPI MIE Mercruiser (serial number M317417). I attempted to start the engine for the first time last night and I turned the starter over multiple times and after attempting to start the boat about the 7th time a extremely loud explosion went off in the engine (or exhaust possibly). The "explosion" was very loud. Much louder than a typical engine backfire. It was as loud as a shotgun. I don't think it caused any damage but can't be sure without actually looking into the engine. Just wondering what could have possibly caused this and want to make sure it doesn't happen again. Here are some notes/thoughts/things i've checked:
- I'm 98% sure I set the ignition timing correctly. I set the distributor rotor pointing when the engine was at TDC for the number 1 piston just as it says to do in Mercruiser manual #31 for my engine. I checked TDC by lining up the 0* mark on the harmonic balancer with the mark on the timing chain cover. I also verified TDC by using a piston stop tool threaded in the spark plug hole. This confirmed that the harmonic balancer mark was correct. Is it possible that my engine remanufacturer put the harmonic balancer on 180* out so that the timing mark is showing 0* (TDC) when this is in fact not TDC between the compression and power stroke (like it should be) but rather TDC between exhaust and intake stroke? I'd think this would be very unlikely but maybe possible. I had the engine (longblock) remanufactured by a very reputable, professional company so I would like to think they got everything correct on their end. I've done the install myself however.
- I've checked the spark plug wires to ensure they are all on the distributor and plugs in the correct firing order. All new spark plugs also gapped at 0.060" and plug wires are in good shape. Not completely sure that the distributor cap is even getting ignition to it so I need to check that tonight (not that this would have caused an "explosion" though).
- All brand new Bosch fuel injectors have been installed as well.
- Fuel rail is getting fuel pressure to it. Haven't measured the PSI but fuel is also getting to the cyclinders (or at least the number 1 cylinder as I smelt gas on the spark plug when i removed it).
- Is it possible that after having tried repeatedly starting the engine that there was a lot of unburnt fuel in cylinders that got dumped into the exhaust causing the fuel to ignite in the exhaust and thus the "explosion"? However, I don't know how the fuel would have got ignited in the exhaust since the engine wasn't warm and thus no heat in the exhaust.
- I did see a little bit of smoke coming from the front of the engine from in between the thermostat housing and the throttle body when I was turning the engine over but I have a feeling this may be a separate, unrelated wiring issue. This was before the explosion occured. Not sure but just wanted to mention this.
- This may be a dumb question also but is it possible i have the starter wired backwards causing the engine to spin backwards when I try to start the engine? Not sure if a DC motor can spin backwards if current is flowing in the opposite direction.
