- Joined
- Jul 18, 2011
- 19,570
I did some clean up work on the ignition switches this morning. Easy access by removing the panel
The connections and the wiring looked OK . . .
I removed the screws on each connection at the switch, then cleaned the contacts and re-assembled. Then buttered them with electrical grease.
The main connectors had plenty of grease in them already and they looked OK.
I cleaned up the wiring a bit and put it all back together.
I still could not find any inline fuses, and I would think that they would be located near the ignition switches. I also took a look at the circuit breaker connections and those seemed to be well greased and in good condition.
Of course, the engines started up without issue, but there is no telling if that will be the case going forward. IF the problem persists, I will probably work my way back to the engine bay and check connections and grounds in that area.
It seems that electrical issues are often tough to track down.
