krustyCrab
Thread starter- Joined
- Jul 1, 2014
- 27
Hello All,
I just encountered a problem with my motor that I cant seem to figure out.
Specs: 1986 4.3l V6, Stringer, Rochester 2gc carb
I picked up this boat a few weeks ago and after some troubleshooting I was able to get the motor started and running like a champ. The issue there was timing which once corrected was no longer an issue. I started and ran the motor several times, put it in gear and verified sterndrive was functioning, All was well at this point.
I didnt run the motor for 3 days while I fixed some other non-mechanical issues with it. In that three days the only work on or near the engine was re-doing the exhaust, i was having some leaking and i buttoned it up with new hoses etc. I also re-wired all of the lights in the boat, grounded it all and just familiarized myself with the electrical.
So yesterday I decided to fire up the engine to verify all was good in preperation of splashing it this morning. Well no luck, initially it sounded like I wasnt drawing enough power, perhaps I made some mistakes with my wiring, so everything I did I ripped apart and low and behold the engine started cranking with full power like I expected. However it would not stay running, what I mean by that is if i keep the key turned the engine sounds like it was running, but as soon as i let go of the key nothing.
I tried absolutly everything I could think of today, I retraced all of the electrical looking for any possible shorts or improper grounding, I replaced the ignition, replaced the fuel pump, verified i have fuel to the carb(when i throttle down I see my primary squirts), I pulled the coil wire at the distributor and verified that I have spark, I pulled a plug wire on cylinder 1 and verified spark, readjusted the choke, verified oil was clean and at the appropriate levels, verified power to my assist solenoid.
I am at a complete loss at this point, I dont see a kill switch anywhere, my wiring all looks good to the gauges, im getting enough juice, I am fairly certain im getting fuel, I know im getting spark. I had this engine running three days ago and didnt do anything that could have caused it to stop running.
Any help offered would be appreciated.
