kippstakes
Thread starter- Joined
- Jun 10, 2013
- 117
Here's the thing, I bought an engine with no key. The key switch key number is rubbed off long gone, so I've been using an old key that fits the keyswitch but isn't cut for it, which means a lot of jiggling and wiggling to get the key to turn (very time consuming). SO, my plan is to simply leave the key in the 'on' position permanently and wire in an on/off toggle between the keyswitch and battery on the B+ wire (Red/Purple).
Here's the question, when the key is in the on position, the A and B terminals are connected- 12v to the accessory (power pack?). In the off position, however, the two M terminals are connected and the power pack is grounded out. If I only install a switch that cuts power to the keyswitch, the power pack will not be grounded since the key will still be in the on position. Will this cause a problem or drain the battery?
http://www.maxrules.com/graphics/omc/wiring/REMCONTBOX.jpg
Thanks
Thanks
