Best product to get rid of oxidation?
Jtgetts
Our '88 Celebrity is horribly oxidized. I'd welcome any and all tips on removing the oxidation. I wouldn't be so concerned but she's all red and I'd like to get that shine back. I'll be doing a full interior restore this winter with a little exterior TLC. Thanks in advance!
Woodonglass
If you don't ever plan on doing anything else to the finish, like re-gelcoating it or painting it, then the provided link is an option. I know MikDee has used it and likes it a lot. I personally do not like it and don't recommend it but I will admit that it does increase the shine and enhance the look and appearance of the dull faded gelcoat. There is a price to pay for using it however and it's not a price that I personally am willing to pay. If you ever try to restore a boat that's had this treatment applied you'll know why. There are several threads here on the forum that you can search for and read that will give you the pro's and con's and discussions on the subject. I'd highly recommend that you research and read them before using the suggested method. You may not be of my persuasion, and if not, then by all means use it and be happy!!! It's your boat and you're free to do as you see fit.
sea wolf
My boat is an 87 StarCraft with a red & white hull. And the red oxidies of course. How do I remove it? I gtrab a jar of Vaseline & rub it in with a pad. Let it dry for a few minutes & wipe off. And 90% of the oxidation is removed. I then wax the boat & I'm good to go for the season. The downsize is its only good for a season.Try it on a small area of your boat if u like & see what happens. Can't hurt.
sea wolf
I just checked that link referencing Vaseline. I just wanted to add that I've been doing it that way for years with no issues. Just saying.........
Condor1970
I've been battling the same problem with my 1989 Regal Medallion.
So far, I've found only one absolute true method to "get rid" of heavy oxidation from decades of build up.
SANDPAPER!!!!
benjh1028
SANDPAPER!!!!
Agree. Start with 800-grit, then 1200, then 1500. Follow this with a good rubbing compound applied with a high-speed buffer. Finish up with a good coat of wax.
Also need a vat of Icy-Hot for arms and shoulders and a cooler of beer.
Only way to "remove" oxidation.
Jtgetts
Agree. Start with 800-grit, then 1200, then 1500. Follow this with a good rubbing compound applied with a high-speed buffer. Finish up with a good coat of wax. Also need a vat of Icy-Hot for arms and shoulders and a cooler of beer. Only way to "remove" oxidation.
The only thing that sounds enjoyable about that is the beer part!
Condor1970
Actually, I said to heck with it!!!
I went and bought a pneumatic orbital wet sander off Ebay. Yeah, it's a cheapie, but anything to save my arms.
I enjoy working out, but have no need for "wax-on/wax-off" training.
benjh1028
Plus, waxing off can make you go blind!
