overheating after running on muffs for 5-10 min.
Water is circulating.
I put a new thermostat in and instead of the temperature rising all the way to 200 degrees it now stops for a couple min at 140 then just creeps up every min with no signs of stopping.
took intake manifold off and it looks like I am backtracking someone else because the gaskets and water inlet holes are cleaner than I expected. Oil is clean in there as well.
checked the impeller and again looks like previous owner beat me to it.
One riser was a lot hotter than the other one so I disassemble that and noticed this crack in the exhaust manifold.
could this be the problem? I know it needs to be replaced but does it sound like there's more to it?
