nurseman
Thread starter- Joined
- Jun 2, 2013
- 1,045
More progress today. Started by grinding down all the nubs from my first attempt with the PB, not too bad, just used the DA and some 40 grit to set things right. Vacuumed the hull and gave it a good wiping with acetone. Sorry, no pics of that, as I assume most of you are well acquainted with grinding/sanding and don't want to be reminded of the experience. However, I do have a little trick to share. I was wearing mask and goggles, but since I wasn't grinding, I didn't put on the full Tyvek suit. So after, the arms were slightly itchy. When I was doing my initial grinding, I tried this and it works pretty well. Take a piece of masking tape, and stick it on where the itch is, and then pull it off. Simple, yet effective. The tape will stick to the fibers stuck in your pores, and pull them out when removed. I'm sure I'm not the only one to do this, but there it is.
So, back to the boat, I set my stringer assembly in place and re-installed my guides and clamped the stringers to the guides. I was using some 1/4 inch square pegs for spacers.
My PB bag with the tip cut off.
Got the bow section done with the first batch. After it kicked, I removed the front guide
But then Murphy showed up....
