nurseman
Thread starter- Joined
- Jun 2, 2013
- 1,045
And last, the paint. I realize that some of you were thinking I was nuts for re-doing it, but I'm glad that I did. As I mentioned before I decided to re-do, I had sanded with 600 grit between coats in an effort to get rid of scratches showing through the coats, and I was having adhesion issues with the paint. So I stripped it back to primer and started over, this time only using 240 grit on the primer, and a red scotch pad between coats (wet). I also made sure to let it cure for several weeks before trying to mask over it. I had no issues with adhesion this time around, so I am happy with it. I would rather take the time to fix a known mistake now, than to risk having it come undone later. So here is the final paint on the hull.
So that brings me up to the present.Hope everyone has a safe and fun Memorial weekend!
