1978 mercury 1150
Jhabuda88
When i try to start my motor it doesnt turnover but you can hear a low humming sound when you try to turn it over. Any ideas?
Bad battery / bad battery cables / bad starter motor.-----Is this something that showed up all of a sudden ? ---Try charging the battery as a simple first step.
Jhabuda88
Battery is good, an it is charged, it has just happened, i tried to crank the motor and nothing, i tried it couple weeks ago and it was fine. I had to take the lower leg off, so i dont know if that has something to do with it. Could the shaft have something to do with it?
commodoreswab
May be the brushes in the starting motor. Ive had that problem before, took it apart cleaned the carbon out and she worked great. It can be a little tricky getting the brushes all back in their places and together.
Jhabuda88
Well i will have to take do some reading on that, i dont know what the brushes really are. I hope its nothing to serious.
Jhabuda88
Well i will have to take do some reading on that, i dont know what the brushes really are. I hope its nothing to serious. If i turned the propeller by hand couple times and put compression in the motor would that mess anything up?
It sounds to me like the starter is spinning, but not engaging the flywheel. Verify that, and then clean the bendix. That is turn the starter motor and hold the gear. The gear will rise up to meet the flywheel. Now clean the "screw-like" mechanism under the gear with some paint thinner or alcohol. Now lube it with some light oil.
Jhabuda88
Starter is not engaging flywheel how do i fix it?
Jhabuda88
I held the starter motor and it didnt rise, it needs a little push up to rise. I cleaned it and lubed it.
