Yes. That is the one I'm taking about. The diagram I posted is different then the one you posted. I'll give it a try. Thanks!if you mean the one that goes into the carbs inlet .the opening faces toward you .install the spring, then the flat end ,then the line nut![]()
Why does working on this boat turn me into such a dumbass? A little pipe sealer goes a long way...
