CatriderF7
Thread starter- Joined
- Jun 8, 2011
- 126
So Im in the middle of an engine swap. the boat is a 1990 with a non balance shaft, non vortec 4.3. I bought a used 1993 Vortec 4.3L With balance shaft in it. The old 1990 intake doesnt fit it because it has a bulge that hits the balance shaft and keeps the intake an inch or two too high. So I ordered an intake off of a Vortec engine and the bump on the bottom of the intake is much smaller. (it looked flush in the pics on ebay) but its still too much and this one also hits the balance shaft.
- So what intake do I need to buy to not have this problem? Is just removing the balance shaft an option if I switch over the timing chain setup from the non balance shaft engine?
I had another post mentioning this but dont feel like trying to find it, and I think it started off as a different topic anyway.
I have a 1993, Balance shaft 4.3L to put in my boat. Problem is the original engine is a non balance shaft engine. And my intake off of that engine doesn't fit with the balance shaft. Is it possible to eliminate the balance shaft in my new engine so as it use the old mercruiser intake? I tried buying a newer style intake off ebay but it still doesn't clear the shaft. Only other option I see is to buy an edlebrock intake which is like $300. I paid $250 for the engine and am not willing to spend $300 on just an intake. So what I want to do is combine these 2 engines, using the old timing set. is this possible? I haven't taken them apart to see if everything will swap out easily or not. I also believe Ill have to plug the oil passage for the shaft after removing it but that wont be a problem as long as everything else swaps out easily
