Luke,
I've investigated the SW paint you're going to use. It's basically the same formulation that Rustoleum uses and Majic Paints uses and all other Oil Alkyd Based Paints. Rustoleum doesn't recommend using hardener either but... it works just fine. It's your boat and your decision but this paint is NOT rated for total immersion. If it's only for inside the boat and above the water line then the use of a hardener is probably fine. But...If it for the outer hull, I'd recommend you use the hardener. It'll work just fine.![]()
Okay I'm really wishing I had a crane! I could really get into trouble with one, but it would really come in handy.
Nice work on the hull sanding. I bet your arms were jello. Sanding or doing anything over head puts more strain on your sholders and arms than you might think. That's the advantage to flipping the hull over for bottom prep and paint. Ofcourse it requires removing the pilot house in your situation which presents its own problems.
Keep up the good work. Can't wait to see her painted.
I can imagine using chemical stripper up under the there would've been even more of a challenge. :lol:
Cant wait to see your paint job Luke, I have been working on mine to but did not paint it as good as yours yet my goal was to get it in the water i hope to launch it in the next two weeks just to see how the old girl floats... here is a quick pic of the inside of mine i will update my post soon.....
Thanks again for all your help Luke and the rest of ya out there......
