I read several threads and didn't see the info I need yet.
I've got a 90 Javelin 396 fish and ski with 2 TM batteries and a engine cranking battery. Wanting to add an onboard charger to this boat.
I just got a 24 volt 65 lb thrust Minn Kota All terrain on the bow and not happy with the thrust so far. Going to work on the wiring. Here's info:
Boat has two 12v marine batteries in stern for TM.
Each battery has a 6 gauge positive and negative cable run to the bow TM receptacle. (four runs)
Receptacle has two jumpers to a 12 volt / 24 volt switch on the bow
I want to use one run positive cable to the receptacle, and one negative (other battery) cable, and jumper the other pos and neg terminals at the batteries to create the 24 volts I need. This will eliminate two 20 foot cable runs from my system (And a circuit breaker) and leave me with 24 volts only. Hoping this will boost TM performance.
I don't know how the chargers work and what extra steps are involved to charge these three total batteries I have. Can someone enlighten me please. Thanks much
