JASinIL2006
Thread starter- Joined
- Feb 10, 2012
- 5,769
Hi all, I'm having some problems with the power tilt/trim on my Alpha 1 Gen 2 drive. In addition to the controls at the helm (rocker switch for up/down, with a separate trailer button on the shaft of the throttle control), I installed a remote (genuine Mercruiser) switch on the transom. The intermittent problems predated the installation of the remote transom switch.
It started with intermittent problems with the trim in/down; I'd press the button, the solenoid would click, and the drive sometimes would trim in, sometimes not. The trim up/out switch also had some problems, but much less frequently. The trailer switch (to raise the drive) has worked fairly reliably. Recently the trim in/down switch has become very unreliable. It generally doesn't work without multiple pushes on the toggle switch; sometimes, hitting the up/out button before the down/in button helps, but not always. The solenoid clicks, but the trim pump generally won't run to trim in/down the drive.
In an attempt to figure out what was wrong, I followed the troubleshooting steps in the Mercuiser manual at the top of p. 1C-14 "Power Trim Pump Motor Runs in the OUT/UP Direction, But Not in the IN/DOWN Direction" when the IN/DOWN solenoid clicks.
I first checked for loose/dirty connections (#4 and 5 in the diagram on p. 1C-16). I checked them (all looked good; clean and no corrosion), and I pulled apart the harness plugs, checked for corrosion and reseated them. I then powered up the pump and tried again. I also checked for a bad trim in/down solenoid by checking voltage at terminal 5 (on the 1C-16 diagram) while pressing the trim in/down button. I checked this by attaching one probe of my mulitmeter to terminal 5 and the other to the negative terminal of the battery. When pressing the trim in/down switch, the meter showed 12.6 volts; when the switch was not depressed, I got 0 volts.
After running the tests, I removed the leads from the multimeter and tried the switches again. This time, not only did the trim in/down not work (except for the solenoid clicking), the trim out/up didn't work at all; it didn't even click! The trailer button, however, DOES work and raises the drive.
So here is where things stand now:
- when I hit the trim in/down button on the throttle control or the transom-mounted control, the solenoid clicks but the pump doesn't run (19 out of 20 times); when the pump does run, it seems to run normally
- when I hit the trim out/up button on the throttle control, nothing happens; no click, nothing
- when I hit the trailer button, from either the throttle-mounted or transom-mounted control, the pump runs normally and the drive raises as it should.
I'm stumped. I'm not sure what I should be doing to systematically troubleshoot this problem and I'm really trying to wrap my head around how the trailer switch works but the trim out/up switch does not.
Any ideas how I should be approaching this?
Thanks,
Jim
Thanks,
Jim
