Boat is an '87 Starcraft 19 ft. powered by a 3.0 Cobra drive. The bilge has been taking on water enough where I have to run the bilge pump every few minutes. Today I jacked the trailer up & filled the bilge with a garden hose. Lo & behold I found water leaking out of the bottom of the transom assembly where the anode meets the bottom of the hull. I didn't want to fill the bilge any further so as not to flood the starter. Now how do I proceed? The transom feels solid. Is there a seal behind this transom assy? I don't have the means to pull the engine & I don't want to go there anyway unless absolutely neccessary. What do you guys think? Will I gain anything by pulling the transom assy. for a look see?
