Flywheel removal
loiner1965
Will remove the flywheel to check coils and magnets on my b7.5 for piece of mine. I will make up a metal plate to hold the f/w still whilst I undo the nut but what do others do ?
loiner1965
sorted.....took engine to work and used an inpact gun on the nut lol
loiner1965
well .....i basically put the nut back on and tapped it with a hammer
both primary and ignition coils have readings co i am now going to check the points.
apparently this is not an uncommon fault
pvanv
Lucky you. Flywheels have been cracked by doing that. You will be fortunate if you can get points and condenser, apart from used, or an olde tyme dealer, or olde tyme NAPA store.
loiner1965
That's something I didn't think about as being Honda I though bits would be plenttiful Anyway.......compression is 125 psi in each cylinder and water was found in the thermostat housing minus stat so it proved the engine as been running... I personally believe its the condenser at fault as the points were were really bad but these engines are notorious for a weak spark. Sourced a new condenser here in the uk which was cheap and it's on it's way Points are mega expensive but being Honda they were issued on motorcycles too so I can buy those cheap too Hopefully when these parts arrive it might work.......or just another piece of the jigsaw lol
