latemodel
- Joined
- Apr 30, 2006
- 21
Hello,
I have owned and worked with a number of 60 HP and 75 HP Scott three cylinders outboards, but never a generator model. In 1958 Scott marketed their first three cylinder outboard. It was rated at 60 HP. It had an automotive type generator and used three sets of points driven off the bottom of the generator. It also had a remote mounted relay/voltage regulator control box and a dash panel with an overheat and generator (charging) light.
The 59 model was almost the same and still used the generator.
In 1960 Scott made a number of major changes to the 60 HP. The generator was replaced with a flywheel alternator. The control panel was smaller and the indicator lights disappeared. The relay and regulator box also disappeared and the entire wiring system was streamlined. Finally, the three points/three coil system was replaced with a distributor and a single coil. In 1961 Scott upped the 60 to 75 HP and the 60 HP was discontinued.
I am currently restoring a 1957 Herters Flying Fish and want to use a Scott 60 HP, but ACBS judging requires the motor be within two years either way of the boat build year. I decided to use a 58 or 59 generator version 60 HP. I found both a 58 and a 59 and bought both. One will be a parts motor.
My problem is that all my Scott factory parts and service manuals are for 1960 and up three cylinders and I have not been able to locate a service manual or wiring diagram for the generator version. Unlike the 1960 and newer three cylinders, Scott did not put a wiring diagram in the inside of the hood. There is a relay/regulator box hook up diagram, but no system diagram.
I would like to purchase a 58 or 59 service manual or wiring diagram, or possibly trade Scott parts for them. I have been all over the internet including Discount Marine and Liangs looking for a manual.
Any suggestions appreciated. Thanks.
Don
Lakeville, MN
Don
Lakeville, MN
