TwoRivers
Thread starter- Joined
- Mar 10, 2010
- 354
Looking for some direction? Just picked up a 16ft. Bass Tracker with a 70 hp Evinrude Tracker outboard. From the model # TJ70TLCEM looks to be from 1989?
Just started looking into it and I'm trying to determine how far to go with this engine.
It is getting fuel.
There is no spark at the plugs.
I did a compression test and there is 100 lbs of pressure in all three cylinders.
I've read stories about compression not being that important in 2 strokes but I'm trying to determine if this reading is acceptable before proceeding further?
So my question : Is 100 lbs of pressure in each cylinder acceptable or can I tell from the reading if this motor worn out?
I don't want to waste a lot of time and cash figuring out the ignition or electrical problem(s) if there is a problem with the compression?
thanks in advance
rob
It is getting fuel.
thanks in advance
rob
