Rick Stephens
- Joined
- Aug 13, 2013
- 6,118
Bought a 1990 boat with a 3.0 Merc a year ago. With a lot of assistance here have fixed repaired adjusted and made my way through many of the systems. Engine history is unknown. In general runs pretty decent. The engine has used no oil after a couple hundred hours use this summer. Looking inside each spark plug hole with a borescope shows what looks like a brand new engine. Clean hone marks, few scratches. Virtually no carbon build up. Same in the rocker cover. Absolutely pristine clean up top.
I have had some issues with water in the outdrive and the shifter killing the engine. It took basically going through every detail to get it fixed - adjusting the cable linkage exactly to spec is important. Nice to have done it, between being nose deep in the manuals, reading here and watching achris's videos, I am getting a great working knowledge of this boat.
Now I have a rough idle. At first, I thought it was a lot worse since the tach is off by several hundred - reads high. With the dash tach saying I was idling at 1100 RPM I couldn't get it to run at all trying to reduce it to 800-850. Attaching a good diagnostic tach showed me the error and I can set idle ok where I want it.
Engine feels rough at 850. So replaced plugs, checked timing, rebuilt carb and ran it pulling wakeboarders for a day. No problems except that rough idle. So hooked up a vacuum gauge. And I am stumped. I have never seen a vacuum gauge work like that in an unblown engine. I could see it with a high lift cam, but I can't believe anyone would make one for a 3.0L, let alone install one. At idle to about 1300 RPM the needle rapidly oscillates between 10 in and 15 in Hg. At 2000 rpm it settles down to 17 inches with barely a flutter.
Maybe the engine was rebuilt and they did the valve guides incorrectly?
I am going to try and post a link for a video I shot of the vacuum gauge. I have had a lot of trouble posting links, so I may not get it done. We'll see.
Youtube video https://www.youtube.com/watch?v=w_boOaxU8FM
Rick
Rick
