Flamethrower coil 470?
philbullet
Has any notice a difference in proformance from a stock coil?
thumpar
The only way you will get any noticeable difference is if you switch to the Ignitor electronic ignition with it. I put in an Ignitor II and Flamethrower II. I did notice a little improvement in starting and a couple hundred RPM increase. YMMV
The spark jumps the gap at certain voltage. If the gap stays the same, the voltage stays the same. If you aren't igniting all your fuel, you have a different issue.
philbullet
Yes i have a electronic ign. and a Duralast coil from autozone with internal resister.Not have any problems at moment just wondering if it help with HP.
I am pushing a lot of wight at times.Running a 21 p. 4 blade my need to drop to a 19p when i heavy a heavy load or a v6 - v8 LOL.
It won't increase HP. Out of curiosity, what electronic ignition do you have?
