CatriderF7
Thread starter- Joined
- Jun 8, 2011
- 126
I have a boat that sits fine in the water and at no wake speeds. But right when you get on plane it immediately starts to dip on the right side. Its bad enough to where the first time I drove it, I immediately let off the gas and checked the bilge to see if we were taking on water. The boat wasnt sinking, but it felt like it. If i let the wheel go straight it will dip on the right side, I have to counter steer it to the left a little in order for the boat to drive straight and level.
Maybe an outdrive alignment issue? I was going to swap the prop out and run it again. The one on it is pretty weird looking. Looks like its been repaired but its more obvious than any other prop ive seen. But im not sure if a prop could even cause this. Ive never had the outdrive apart or off, but I dont know anything about its past
