Rehab SportCraft 222 1983 deep V hull cuddy walkaround
kcassells
floor ques 1.jpgfloor ques 2.jpg I have a question guys you can help me with. In the wheelhouse to be I have a very small spot to run the new glass floor into.There are 2 storage wells left and right. I was thinking about blocking under the wells and run the glass up the well. Just wondering if you think vibration might break it apart at some point.
1 side I have space of @ 1" other side gets tighter. I don't think I'll be able to roll and work the glass in there properly.
All suggestions welcome.
kcassells
o I was picking my nose to see if I could use that for a filler? Seems pretty good and the glass takes to it pretty good.
Moving along....
sphelps
Grinding dust from the nostrils may take a bit more hardener to cure properly ..
Just me thinking seeing as your using eeeeepoxy .. I doubt you would get much cracking if any ...
oldrem
Might be too hard - may require rental of a wrecking ball if you ever wanted to redo things :)
mickyryan
Think you would be fine i mean there cant be that much movement between top and bottom
kcassells
Hey Guys,
zool etal,
I'll need some help here Poppy Zool.
This ole boat I'm working on is killin me. Obviously my skills blow ya see. Including MULCHING MY FREAKIN GARDENS. Thinkin I'm getting off the SportCraft and move into something I JUST MIGHT BE ABLE TO COMPLETE!
:lol:
Ya'll have a great Day!
Zool...? kinda like yours? whats ya think?
