Rehab SportCraft 222 1983 deep V hull cuddy walkaround
kcassells
wog , Yes I have been researching into that. Seems feasable. Heat, cool and bend. I guess I would have to make a buck to do the banging and bending on. :D
back to todays playtime. All is setting up well. Took meas. again so all bolts will work out just fine. That pc. of poly I used to stuff the gardboard drain in turned out great. I'm looking at it after I plulled the poly and was cussing thinking the plastic adhered to the EEEpppoooxxy. Then looked at the poly I removed and the only tear was from the screw.
So back to sanding and priming tom.
Happy Labor Day everyone!
mickyryan
raptor liner works well , however i think for capping the aluminum idea is pretty sound but you could spray the liner on the cap then just put aluminum where the engine sits
kcassells
ahmincha
Good hearing from you! How's the boat and family doing? Put some pics up w/some fishysss. Ya know the sound of the "Splash" doesn't seem a distant sound of past. Pretty exciting!
The KFC'ter
mickyryan
Yea Mick just toying around with some ideas.:D
kcassells
Got a bunch done this morning. Kinda messy and boring. I'll post later. :)
Plus I messed up my cell connections and lost stuff. Like email and wifi.
kcassells
Thanks guys! All nuttin but rain here last 4 days and most this week.
kcassells
Thanks Mick,
What a pisser this weather is!!! No rain at the moment but fog you need a knife to cut thru to see. What gives there Mr. President and no environmental impacts from green house effects? I think the next township over must be having a "Dry Ice" parade.
Humidity ahhh a mere 100%. No rain at the moment...wait...maybe I'll go run out and paint the transom.
I just want to knock that out....last week. Maybe sat.
Utter dan dat guys wish I had a barn Like wog is building.:D
mickyryan
yeah well could be worse you could be having the weather someone on the east coast is going to get , then you woulda wished ya splashed her:)
zool
Best to hold off on any paint right now Kev, if the humidity dont get to the paint, the skeeters will!.......I just spent some time in the barn cleaning up a old table saw I dug out to replace the one I burned out :D
kcassells
Just got the itch to see how the color turns out on the transom. I'll have to move on to the mundane issues I keep putting off.
