theoldwizard1
Thread starter- Joined
- Feb 25, 2014
- 341
My Starcraft uses the Attwood seat bases and posts. The bases are cat aluminum and are looking pretty sad with a lot of corrosion. I placed 2 of them in bickets of vinegar (5% acetic acid) for about 2 weeks. It appears to have changed the corrosion (oxidation ?) black but really not removed much. After about 30 minutes with 120, 180 and 240 grit sandpaper on an oscillating tool, they are better but far from perfect.
What next ? Stronger acid ? Buffing wheel (I have a 4.5" grinder) and compound ? Right or wrong tool ? What kind of compound ?
Problem #2 is removing the post from the other 2 bases (they are out of the boat). Liquid wrench seems to have no effect. Several hits with a rubber mallet have had no effect.
