Introducing antifreeze via the flusher device is a dangerous gamble, as you will never know the concentration in the motor, and you will never know that the entire motor has been treated. The simpler, more effective and proper way to introduce antifreeze is as follows.
After all other winterizing has been completed.... remove the block and manifold drain plugs ( 1of each on an inline motor, 2 of each on a V engine) on the motor and let the water drain. Pour straight antifreeze into the large waterpump hose, until you see the color at one block drain. Install that drain plug. Continue to add antifreeze until you see it at the other drain (v engine only) Install the remaining drainplug and fill the block with straight A-F.
Pour straight A-F into the manifold hose, until you see the color at the drain. Install that drain plug and fill the manifold with straight A-F. It will exit the prop as well. Repeat for other manifold, if you have a V engine.
Pour straight A-F into raw water hose until you see color at water intakes. This flushes the power steering cooler.
In the spring drain the engine and manifolds and save the antifreeze for next winter. My 4.3LX Mercruiser would take about 4 Gal to winterize. I saved the containers and refilled them in the spring, and put them on the shelf in my garage.
