going out tonight to take care of it, gonna put some gas and stabil in, start it up and let it warm to operating temps on the gauge, shut it down, wait to cool and drain block. Block and suck through blue drain hoses(one in block and other in manifold) to ensure all is drained. then ill pull the big hose off the t-stat housing, fill with a/f and wiggle all hoses to ensure it's all sucked into the engine, reinstall hose. then do the same with manifold, whichever hose is highest feeding it, fill with a/f, then reconnect. wiggle all hoses again to ensure a/f moves around and burps any air or what not.
then pull blue drain hoses again and collect antifreeze. after that pull it inside, put drive all the way down and be done. my primary reason for a/f is to just help "oil" the insides and what not. as far as the drive, I haven't really read to much or seen anything in the manual about a/f in there, so ill just keep it in the down position to be completely drained and assume it's good. hope this works! thanks everyone again
