Condor1970
Thread starter- Joined
- Jun 9, 2014
- 195
How many of you put your trailer up on jack stands in the winter so the tires/leaf springs don't have all that stress on them from sitting for months until spring?
Until they crack! Just don't go crawling under anything that is being supported with cinder blocks. Worst thing you can use.Guilty but I use cinder blocks. Seems a little more stable.
right, that's why they used to support a motor home. Besides, you think I just use one? there is a way to use them properly but hey, don't ask how I use them, just assume if I don't do it your way, I'm doing it wrong.Until they crack! Just don't go crawling under anything that is being supported with cinder blocks. Worst thing you can use.
I like this idea. If you store in garage it wouldn't mark up your floors as bad. I use non-slip shop tiles to protect my floors and I wrap the trailer frame with old bike inner tubes where the cinder blocks will come in contact.landscape timbers ok?
Hey no problem. I just posted this in case anyone else decided to try cinder blocks so they wouldn't do it.right, that's why they used to support a motor home. Besides, you think I just use one? there is a way to use them properly but hey, don't ask how I use them, just assume if I don't do it your way, I'm doing it wrong.
Right and I'm just mentioning other options that might work for others. YMMVHey no problem. I just posted this in case anyone else decided to try cinder blocks so they wouldn't do it.
I wouldn't bet my life by getting under a vehicle supported with them. Kinda goes with my saying about common sense.
I do if they are used properly on a flat concrete surface but I add wood blocks(NOT CINDER BLOCKS) and my hydraulic floor jack just in case.But you would for a couple sets of jack stands?
Oh man now THAT'S terrible news... here I've been parking trailers from 10-40 feet long in the grass for nearly 30 years and never had a single one sink or ever had any trouble pulling one out in the spring and NOW I learn that without plywood I'm gonna lose em all this winter.... sure wish I'd have known that before ....
As for risking my boat... uh noooo I wasn't risking ANYTHING and my buddy was the dope who risked his shoulder... not my problem... I certainly didn't suggest that he run full speed into a 10,000 lb boat but no way was he gonna hurt it...
Do what you like but understand that for every one person who has the sense to stack concrete blocks as I described above there are 40 or 50 bozo's who lay em on their side and might get killed....
Suggesting that jack stands are somehow less safe than concrete blocks is silly
Yep...you use them for walls or to support buildings. You know...what they were made for. Not for point loads.there is a proper way to use cinder blocks.
