anderso8623
Thread starter- Joined
- May 25, 2012
- 388
My rude has had the carbs cleaned by myself once and a shop twice in the past two weeks. When I opened them up, they where surprisingly clean for a motor that had been sitting for 25 years as the PO stated. I cleaned them anyway. Sent it in for high rpm on the hose. They stated it needed a few things and ended up completely rebuilding the carbs. They found a large seed under the Welch cap...I think that's how you spell it... Dropped the boat the next day and it took off like a bat out of hell, I slowed down to idle and then throttled it back up and I could not get it over 10 mph and no rpm at the time. Took it back in that day and they made some trotted adjustments with no luck. Dropped it off again today and the tore the carbs down again and found what looked to be like a piece that was stuck on and broke free after I have it on the water. Took it out again and same thing, took off great but after I idled down I could not go fast again. This time I had a tach and remember seeing 5000 on the first hole shot but could barley break 4000 after. I maxed out at about 23 mph and 4000 rpm after using the choke a few times while WOT to convince it to get that high. Any suggestions?
