Grub54891
- Joined
- Jun 17, 2012
- 6,428
Mercruiser 140, 1985 Serial number:6920193 I'm in the process of " refreshing" the gaskets/seals in my 140. Upon removing the timing cover,found a couple chipped teeth on the fiber cam gear. No big deal...or so I thought. Ordered the new gear,found it to be about .30 thousands larger in diameter. Thought it was just wear,but there is no way the cam will go in,and mesh with the crank gear. My main concern is there a different spec for the marine motor. I thought the gm motor was the same as far as the cam gears go.I dod get the new fiber gear from the local napa. Everything else matches- tooth count ect. Anyone run into this issue,or do I have to get the crank gear to match up? Crank gear is steel and in good shape otherwise. Anything I look up for parts or specs comes up the same,even at napa.
