Jared9220
Thread starter- Joined
- Dec 29, 2010
- 59
Good work and progress. WOG is referring to the structural aspects under the floor as they existed. The stringers/bulkheads/deck structures will end up being a result of putting back what was there.....in a better fashion and the deck mods will at some point tie back to the under deck replaced structure.
So then if you are contemplating like a long bench etc for "sunning" in addition to the existing structure being replaced you will want to consider modifying whats under the deck to accept the deck/bench mods. for strength and integrity.
Pics/meas etc will refresh your memory cause these rehabs last longer than your mind remembers. They end up being great references.
Thanks for the kind words.
I was lucky enough that another member on here has already rebuilt this exact same boat so I can look back at his rebuild for help.
http://forums.iboats.com/forum/boat...at-projects/326960-1992-wellcraft-excel/page2
I think I understand what you are saying about thinking about what will be above when building the structure below. Basically you are saying if there will be something heavy above, build better support below to carry the load. Am I picking up what you are putting down?
